Ke70 Clusters
yesterday i took a trip to the wreckers in bundaberg and after scrounging around i came home with a few things.
the cluster i grabbed however I'm having a few problems with. everything works except for the lights behind the gauges that come on with the parkers.
i tried cleaning the contacts at the back where the harness plugs in, putting the bulbs from the other cluster in and still nothing. any ideas?
The switch which controls how bright the dash cluster is.. is it plugged in? If this is left unplugged, the lights won't come on when you turn on your parkers/headlights.
ill try that mate but everything was working before i swapped the clusters over
