harryb Posted July 26, 2009 Report Share Posted July 26, 2009 hey guys. I was recently taking my leaf pack out and the hand brake cable was still connected and it dropped and stretched a little bit . The problem is that on the side that it happened the wheel wouldn't spin so I'm guessing it was jamed. I then took the drum housing off to see if the shoes could be pushed back in and I can't get the housing back on at all. and can't get the shoes back in anymore. Any ideas on getting these back in so I can get the housing back on would be appreciated. Cheers H. Quote Link to comment Share on other sites More sharing options...
TE278U Posted July 26, 2009 Report Share Posted July 26, 2009 Harry, Firstly, i'm assuming your handbrake is off. if it isn't, you will need to put it in the down position. If you know how to adjust the handbrake from inside the car, you should make it as slack as possible to try to get the drum back on. If this doesn;t help, you will most likely need to take out the adjusting mechanism that looks like a strange bolt that goes between the two shoes and wind it in to its shortest length. then you should be able to put the shoes back into thei normal position and put the drum back on. if you are wanting to drive the car with effective brakes later, you will need to adjust the brakes once the drum is back on. If you don't know how to do all of this, i would suggest googling the subject, or searching on youtube. best of luck. -dave Quote Link to comment Share on other sites More sharing options...
harryb Posted July 26, 2009 Author Report Share Posted July 26, 2009 cheers got it. thanks for your help. Quote Link to comment Share on other sites More sharing options...
