December 30, 200322 yr comment_3465 OK guys I have this shop manual here with a crapload of settings. So over the next few days/weeks I'll be typing out all this info for each particular model. I figure I wont bother with auto transmission settings as they suck and should burn in hell. If theres any car 1970-1990 (early 1990) that you would like the settings for (bar all the corollas because I'm putting them up anyway) please PM me and I'll add it to my list! I'll also have a separate topic for each car for easy searching and finding. Once Ive posted the settings I'll lock the thread to keep it tidy Engine Engine Displacement (cc): Firing Order: Spark Plugs Type: Gap (mm): Compression Pressure (psi): Distributor Make: DWELL: Point Gap (mm): Ignition Timing Initial/Static: Fuel System Make/Type: Float Level (mm): Idle Speed (rpm): Emission CO%: Fuel Pump Pressure (psi): Fuel Capacity (cc/min@rpm): Oil Pressure (psi): Valve Clearances Inlet Hot/Cold (mm): Exhaust Hot/Cold (mm): Torque Specification Cylinder Head (ft.lbs): Main Bearings (ft.lbs): Con Rods (ft.lbs): Alternator/Generator Make/Type: Output Amps: Output Voltage: Regulator Settings (V): RPM: Starter Motor Make/Type: Cranking Current Draw: Locked Current Draw: Cranking Voltage: Wheel Alignment *Settings Unladen* Castor: Camber: Toe-In (mm): Report
