1974-76 1.2l Corolla (ke25)
Although this specifies 1974-76 I am pretty sure that it would Include late KE20.
Engine
Engine Displacement (cc): 1166
Firing Order: 1342
Spark Plugs
Type: Denso W16EP
Gap (mm): .80
Compression Pressure (psi): 156
Distributor
Make: Denso
DWELL: 52±2
Point Gap (mm): .40-.50
Ignition Timing Initial/Static: 8@Idle C/S
Fuel System
Make/Type: Aisan
Float Level (mm): 6.5
Idle Speed (rpm): 750-850
Emission CO%: 3.0
Fuel Pump Pressure (psi): 2.8-4.3
Fuel Capacity (cc/min@rpm): 900@5800
Oil Pressure (psi): >45@3000
Valve Clearances
Inlet Hot/Cold (mm): .20
Exhaust Hot/Cold (mm): .30
Torque Specification
Cylinder Head (ft.lbs): 39-47
Main Bearings (ft.lbs): 48
Con Rods (ft.lbs): 38
Alternator/Generator
Make/Type: Bosch
Output Amps: 40
Output Voltage: 14
Regulator Settings (V): 13.8-14.8
RPM: 1000
Starter Motor
Make/Type: Bosch
Cranking Current Draw: 55
Locked Current Draw: <500
Cranking Voltage: 11
Wheel Alignment *Settings Unladen*
Castor: 1°50'±20'30"
Camber: 0°45'±30'30"
Toe-In (mm): 1±1
  • 8 months later...
