irokin Posted December 30, 2003 Report Posted December 30, 2003 I'm really not sure what model this is...seems to be only a limited run of them. The only difference I can find is some emissions changes and a compression drop. This is most likely the 3K-C Engine Engine Displacement (cc): 1166 Firing Order: 1342 Spark Plugs Type: Denso W16EP Gap (mm): .80 Compression Pressure (psi): 149 Distributor Make: Denso DWELL: 52±2 Point Gap (mm): .40-.50 Ignition Timing Initial/Static: 8@Idle C/S Fuel System Make/Type: Aisan Float Level (mm): 6.5 Idle Speed (rpm): 750±50 Emission CO%: 0.3-2.0 Fuel Pump Pressure (psi): 2.8-4.3 Fuel Capacity (cc/min@rpm): 900@5800 Oil Pressure (psi): >45@3000 Valve Clearances Inlet Hot/Cold (mm): .20 Exhaust Hot/Cold (mm): .30 Torque Specification Cylinder Head (ft.lbs): 39-47 Main Bearings (ft.lbs): 48 Con Rods (ft.lbs): 38 Alternator/Generator Make/Type: Bosch Output Amps: 40 Output Voltage: 14 Regulator Settings (V): 13.8-14.8 RPM: 1000 Starter Motor Make/Type: Bosch Cranking Current Draw: 55 Locked Current Draw: <500 Cranking Voltage: 11 Wheel Alignment *Settings Unladen* Castor: 1°50'±20'30" Camber: 0°45'±30'30" Toe-In (mm): 1±1 Quote
