spongebob101 Posted November 10, 2009 Report Posted November 10, 2009 hey, i have a 4k-c and it idles at 1500 rpm can any1 put a picture up or tell me where the idle screw is on the carby or if you think it could b anything else please let me no thanks Quote
!!!! slidwayz!!!! Posted November 11, 2009 Report Posted November 11, 2009 timings out? chokes getting stuck? Quote
!!!! slidwayz!!!! Posted November 11, 2009 Report Posted November 11, 2009 idle screw is under the carby near the strut tower its a gold bolt with a springs down the thread. Quote
kiahn Posted November 11, 2009 Report Posted November 11, 2009 alright here is the thing, there is an air bypass screw and a throttle position screw the air bypass screw is near the bottom of the carby pointing towards the strut tower, screw it in all the way and then unscrew it 1 and a quarter turn and start from unscrewing from there while adjusting the throttle stop to make sure that the idle goes where you want it make sure you have enough adjustability in relation to the thorttle stop to do go from high idle to stall Quote
