Ke17 Coupe
hey
does anyone know if you can fit a KE30 diff and front struts in a KE17 Coupe. Also will the tail shaft fit into it out of a KE30?
hey
With the right modification YES. A whole KE20 (TWENTY!!!) front end is what some people use. As for the diff, if you're looking for strength
there are much better options out there. You really just need a diff with the same or as close to the same width as possible. No the tailshaft
will not fit.
So what will the modifications be to be able to fit a KE30 struts in because i want th same stud pattern as the KE30? With the diff i am looking to put a salisbury diff in not woried about the width because the car will just be a burn out car.
Also i was wondering if this Coupe that i have with a 3K engine has the big bore head on it?
