January 28, 200422 yr comment_4509 Does anyone know if they are the same? I'm tempted to use the KE70 struts I have and put coilovers on them...see as its cheaper. Might grab the suspension arms off that crossmemeber too Nick if they are the same. Report
January 28, 200422 yr Author comment_4514 So an 86 coil over kit would fit? Using KE70 suspension arms should give me 1.5 degrees extra negative camber I believe Report
