R31 Skyline Turbo 5 Speed
hi all, i have a r31 turbo 4 door for sale. its a mad sleeper!
it is an rb30et
this car was purchased from an old lady as an auto and she had it for the last 15 years.
majority of work has been done proffesionally by turbotune on south road.
car has been running on 7 pound, and made 160kw on 7 pound with a few less things done than listed below.
should be good for about 200kw on 10 pound.
high mounted to4E a/r.50 front compressor housing and garrett exhaust housing sitting on a stainless manifold all heat wrapped with 45mm external wastegate with 10psi turbosmart spring and custom made stainless dump and 3 inch straight exhaust dumping down before diff but retaining standard looking rear stock double pipe muffler and stock rims with exec. hubbies:blink:
r31 factory 5 speed full manual conversion
custom short shift kit
exedy heavy duty clutch kit
turbo smart boost bleeder
new 10pound turbosmart wastegate spring
fuel pressure regulator
VLT 3TA manual turbo ecu
rb20 270cc red top injectors custom fitted to standard vlt rail
custom /made fitted 600x300x76 FMIC with piping bent at top of cooler with short piping kit going to turbo and throttle body
s15 fuel pump
chrome skull racing gear knob :ph43r:
dished leather drift style steering wheel
full manual leather console surround mod
standard diff fitted with a boss mini-spool
gearbox/diff/engine oils all replaced with quality oils
pivot custom dash mounted bar boost guage
exterior/interior tidied up eg.door trim rip and broken door buttons etc
reason for selling is i just bought a lowlux and i also am restoring a 1966 mk1 cortina so no more room.
i am looking for $4800 ONO
or i am keen to swap for a yamaha yz250f or 450f bike. i got cash to put in if i need to.
any questions don't hesitate to ask, call or text 0430 541 780 or PM me on here. cheers
Edited by WeBRollin
From the rules that You have agreed to:
7. You may only "bump" (i.e. reply to yourself) your item every 72 hours (3 days) or your item(s) will be removed. No bumps are allowed within the first 72 hours of posting your item. Excess "bumping" is unnecessary, very annoying and unfair to other advertisers.
Feel free to readvertise in a couple of days.
