Dellorto Or Weber Linkages And Manifold Question
first question can a 4af carby manifold fit on a 4afe
i can get a manifold to run twin 40 dellorto carbs or a manifold to run a 32/36 can i use my standard cable and linkages?? or do i have to go custom
what else would i have to do besides plug the injector holes (leave the injectors in i have been told) to run carbs i don't like ecu and don't want to buy a standalone
i can tune and maintain carbs easily and can get as many carbs as i want practically free
thank you for your time
regards Harry
No idea i'm afraid. Someone will know the answer
Dellorto's no. You will need sidedraft linkages, but the cable should do it, maybe with minor mods. Standard cable should work on a 32/36 with minor mods
Injector holes are in the EFI manifold; how are you going to fit carbies and carby manifold to an engine with an EFI manifold still attached?
righto oh my bad (question 3)
so can i just take the whole efi manifold off and swap it for carby manifold
i thought in the first generation head the injectors were in the head as i had to take the rail off the head ??????
Edited by ae95- wagon kid
you'll need to do something with the dizzy as well, the computer controls the timing.
