taking the cam for my 5k in tomorrow. need the cam specs pronto!
I'm converting to solid lifters. The bottom end is all standard ACL gear. Using 4k head, valves, rocker gear and shortened 4k puhrods with 5k valve springs. Ported the head and will be supercharging this motor.
From the FAQ's on camshafts I'm running with the 25-65, 270 degrees, 0.423" valvelift.
The question is will this be ideal for my engine???
