ke20 king Posted September 20, 2010 Report Share Posted September 20, 2010 hi I'm rebuilding a 5k it had 40thou oversized pistons in it but the bores are gone... now i need to go 60thou but can't find 60thou oversized pistons for it... has anyone tried putting sleeves in a 5k does it work or is it too close to the waterjackets and will overheat?? thanks. Quote Link to comment Share on other sites More sharing options...
philbey Posted September 20, 2010 Report Share Posted September 20, 2010 (edited) You can get 60 thou pistons, ACL make them. EDIT: Mahle make them, ACL are the supplier. Edited September 20, 2010 by philbey Quote Link to comment Share on other sites More sharing options...
ke20 king Posted September 20, 2010 Author Report Share Posted September 20, 2010 what about liners Quote Link to comment Share on other sites More sharing options...
philbey Posted September 20, 2010 Report Share Posted September 20, 2010 you can put liners in but you're crazy if you think that's the easiest option. For that money you'd be better off getting another block that can be machined. Quote Link to comment Share on other sites More sharing options...
