keslider55 Posted October 27, 2010 Report Share Posted October 27, 2010 hey guys, ive got a 4k engine and I'm trying to get my redline single dcoe weber manifold on. its got extractors so i had to shave a bit off the edges of the manifold to squeeze it in between. BUT,,, now that it fits on, i just realised the nuts/studs that hold the manifold/extractors on are not going to work because the manifold and extractors have a different thickness on the base plate that bolts on. if you understand what i mean please help me out. :glare: Quote Link to comment Share on other sites More sharing options...
Oh-KE Posted October 27, 2010 Report Share Posted October 27, 2010 hey mate, I had the same problem when I put extractors on. I used a file to make the stock inlet mani the same level. Worked a treat. Good luck. :y: Quote Link to comment Share on other sites More sharing options...
keslider55 Posted October 27, 2010 Author Report Share Posted October 27, 2010 Ok so just file it bit my bit untill it fits or measure it up i guess Quote Link to comment Share on other sites More sharing options...
philbey Posted October 27, 2010 Report Share Posted October 27, 2010 Yeh, I used a file as well. Make sure you file off the back face (that the nut tightens too) I've seen it done where they tried to file the head face down = fail. Take your time and keep checking with verniers. It's only a half hour job. Quote Link to comment Share on other sites More sharing options...
