November 1, 201015 yr comment_479455 Hey everyone Was wondering about the size of the flywheel in the 4agze? Thanks Report
November 1, 201015 yr comment_479492 there are two different 4a-gze flywheels. are you after overall size or the clutch face size? friction face is 225mm or 230mm. they are interchangeable as long as you have a matched flywheel size and clutch size. don't know what the overall sizes are but neither will fit in a t50/c5# bellhousings if that's what you're after Report
November 8, 201015 yr Author comment_480967 okay are the 4age's the same?? i took mine off and measured the flywheel and it was about 267mm and the clutch was about 212mm. is this right? Report
November 8, 201015 yr Author comment_480971 also where are the sizes measured from? any pictures or diagrams would be good please. thanks Report
November 8, 201015 yr comment_481004 okay are the 4age's the same?? i took mine off and measured the flywheel and it was about 267mm and the clutch was about 212mm. is this right? Most flywheels are referred by friction face size. 200mm bigport 212mm smallport and 20v(though black top is the same size, it's a fair bit lighter) both of the above run the same ring gear, just the 212's ring gear is recessed behind the face slightly, they are both interchangeable as long as matched clutch/flywheel is kept. ge and gze flywheels are not directly interchangeable, they have different ring gear diameters, which means different starter positions. Report
