November 9, 201015 yr comment_481288 I'm going to be running a hilux diff in my celica and will most likely keep it 5 lug for avaliablily of wheels. and brake upgrades my q is anyone who has done a 5 lug swap on anything what have they done with the front as I'm stuck for ideas and it all needs to be able to passed with a engineer as it will be a street/daily any help would be greatly appreciated. Report
November 9, 201015 yr comment_481299 there is soooooooo many thing you can use to convert a 4 stud to 5 stud it would be worth reading through a few build threads and finding alot of info on 5 stud conversions, I would suggest looking into a hopperstoppers brake kit they come as a near bolt on kit for rolla's and i'd be suprised if they didn't do one for the ta's man, i think it's about $1250 for a complete brake upgrade and it comes as a falcon pcd, which is the same as a hilux Report
November 9, 201015 yr comment_481302 MS65 Crown hubs are what you want for a bolt on, they fetch a pretty penny though - $300 a set, a quick shave and all the factory brakes will bolt up if they're redrilled to match. MS112 hubs needs machining and custom sleeves machined to adapt the bearing cups, but can be had for cheap. Generic trailer hubs run the same bearing too, if your upgrading the brakes you'd need to run a floating rotor setup on them, but I've never seen this done, but being a load rated I'd say the engineer would be happy with them (don't quote me ask). BTW hoppers won't sell you loose hubs, not legal according to them, as there brake systems are sold as a package. Report
