November 22, 201015 yr comment_483741 Acquired a 3k block, balanced bottom end, bored .75mm with flat top pistons. only needs disassemble, clean, and reassemble How do i figure out what my compression ratio is so i can figure out what cam to get etc? I believe i need to use a syringe to measure the combustion chambers or something? Report
November 22, 201015 yr comment_483748 Yep you'll needa syringe and a flat piece of glass to work out the volume of the head. Download dynamic compression ratio calculator from This link and read the full page. You'll also need to measure your pistons, deck heights etc to get all the info. Once you get cam specs, you will need to punch them into the DDR as well. Aim for a dynamic comp ratio, not just static comp. Report
November 24, 201015 yr Author comment_484062 Yep you'll needa syringe and a flat piece of glass to work out the volume of the head. Download dynamic compression ratio calculator from This link and read the full page. You'll also need to measure your pistons, deck heights etc to get all the info. Once you get cam specs, you will need to punch them into the DDR as well. Aim for a dynamic comp ratio, not just static comp. Thanks,:) Report
