S13 Silvia Sale Or Swapsss!
!!THIS CAR IS DEFECTED!!
Hey all, have up again my s13 silvia for sale but now defected,
Model is a 1989 s13 silvia with a ca18det in it, it is a 5 speed manual intercooled turbo.
Rebuilt on 25/5/2010 : Parts replaced are listed below;
Turbo gasket
ACL VRS gasket set
ARP cylinder head bolt set
ACL Big end bearing set
ACL Main bearings
ACL sump gasket
Ryco oil filter
Bendix general CT front and rear brake pads
Ryco fuel filter
Oil pressure switch
Standard nissan air flow meter
Standard nissan oxygen sensor
Fuel pump
New L/H and R/H engine mounts
New spigot bush
ACL race series forged oversized pistons and rings(http://www.aclperfor...rgedPistons.htm)
Nisstune board computer
Have $4500 worth of reciepts to prove
Block was acid bathed, bored out 40 thou, head was crack tested, straightened and machined.
Crank was measured and balanced.
Has not been molested with big shiny aftermarket parts,
Still has stock side mount intercooler,
nardi steering wheel,
silvia floor mats,
52mm thick radiator,
T25G turbo
Has always been driven on 7psi only gets driven to and from work and maybe once on a weekend, has been on mallala once
Body is quite straight, paint is getting average, clearcoat around sunroof has peeled off and paint is starting to bubble, one small dent in drivers door (suspected car door or trolley has hit it), paint on front bumper is getting average from general driving from stones, rear bar bubbled and starting to peel and 1 chip on each rear quarter (touch up will make them un-noticable).
Also first to second seems to grind when trying to put in when over around 3000rpm and same goes going down from third to second, but work fine when rpm is low.
Looking for something registered and track worthy preferably a ke70/ae71 without a defect.
any other questions feel free to ask, I'm starting at $7000 ono and i am open to swaps, inspections welcome, contact Josh (Me) on 0430931773 or reply on this thread or PM.
Edited by Joshs1456
