S13 Silvia Sale Or Swapsss!
!!THIS CAR IS DEFECTED!! Hey all, have up again my s13 silvia for sale but now defected, Model is a 1989 s13 silvia with a ca18det in it, it is a 5 speed manual intercooled turbo. Rebuilt on 25/5/2010 : Parts replaced are listed below; Turbo gasket ACL VRS gasket set ARP cylinder head bolt set ACL Big end bearing set ACL Main bearings ACL sump gasket Ryco oil filter Bendix general CT front and rear brake pads Ryco fuel filter Oil pressure switch Standard nissan air flow meter Standard nissan oxygen sensor Fuel pump New L/H and R/H engine mounts New spigot bush ACL race series forged oversized pistons and rings(http://www.aclperfor...rgedPistons.htm) Nisstune board computer Have $4500 worth of reciepts to prove Block was acid bathed, bored out 40 thou, head was crack tested, straightened and machined. Crank was measured and balanced. Has not been molested with big shiny aftermarket parts, Still has stock side mount intercooler, nardi steering wheel, silvia floor mats, 52mm thick radiator, T25G turbo Has always been driven on 7psi only gets driven to and from work and maybe once on a weekend, has been on mallala once Body is quite straight, paint is getting average, clearcoat around sunroof has peeled off and paint is starting to bubble, one small dent in drivers door (suspected car door or trolley has hit it), paint on front bumper is getting average from general driving from stones, rear bar bubbled and starting to peel and 1 chip on each rear quarter (touch up will make them un-noticable). Also first to second seems to grind when trying to put in when over around 3000rpm and same goes going down from third to second, but work fine when rpm is low. Looking for something registered and track worthy preferably a ke70/ae71 without a defect. any other questions feel free to ask, I'm starting at $7000 ono and i am open to swaps, inspections welcome, contact Josh (Me) on 0430931773 or reply on this thread or PM.
Nissan S13 Silvia, Forged Ca18det K's Edition
Hey all, have up again my s13 silvia for sale, Model is a 1989 s13 silvia with a ca18det in it, it is a 5 speed manual intercooled turbo. Rebuilt on 25/5/2010 : Parts replaced are listed below; Turbo gasket ACL VRS gasket set ARP cylinder head bolt set ACL Big end bearing set ACL Main bearings ACL sump gasket Ryco oil filter Bendix general CT front and rear brake pads Ryco fuel filter Oil pressure switch Standard nissan air flow meter Standard nissan oxygen sensor Fuel pump New L/H and R/H engine mounts New spigot bush ACL race series forged oversized pistons and rings(http://www.aclperfor...rgedPistons.htm) Nisstune board computer Have $4500 worth of reciepts to prove Block was acid bathed, bored out 40 thou, head was crack tested, straightened and machined. Crank was measured and balanced. Has not been molested with big shiny aftermarket parts, Still has stock side mount intercooler, nardi steering wheel, silvia floor mats, 52mm thick radiator, T25G turbo, fitted today (all new gaskets) Has always been driven on 7psi only gets driven to and from work and maybe once on a weekend, has been on mallala once Have a few extra bits and pieces, couple sets of rims, 550cc injectors, Z32 air flow meter with brand new Tomei wiring harness (will sell seperatly just make an offer), 15m roll of heat wrap, 20 stainless steel zip ties, front and rear brake calipers and lines with slotted front rotors, and probably some other stuff i can't think off. Body is quite straight, paint is getting average, clearcoat around sunroof has peeled off and paint is starting to bubble, one small dent in drivers door (suspected car door or trolley has hit it) and 1 tiny chip on each rear quarter (touch up will make them un-noticable). any other questions feel free to ask, I'm starting at $8000 ono and i am open to swaps, inspections welcome, contact Josh (Me) on 0430931773 or reply on this thread or PM.
Sold
Hey mate did you still want someone to put an add up on nisansilvia?
Ford Corsair, Cheap Daily (sa)
Hey mate very keen on this, will have the money in about a fortnight so ill keep in touch and if you still have it then ill grab it off ya, thanks josh
Sold
No worries, thanks anyway mate
Sold
If still for sale got a 1969 ke10 twin carby worked 4k, let me know, will do a straight swap.
Saturday 29th May
Trying to throw together a little cruise next weekend just bought a ke10 and want to meet other rolla enthusiasts, Pm me if interested for details, Thanks Josh
Joshs1456
