Is it a KE30 with master cyl bolts at 3 and 9 ? Long skinny master cyl with 2 seperate fluid resivours?
If it is, a #E7# master is a direct bolt in.
I know with them, there is a seem that runs across the car above the booster, the lip that is bent 90 downwards will need to be folded up and out to clear.
If you can wait i'll try get some pics from my 36.
Sorry, 3 and 9 O'clock.
Yep. KE70 will fit in. The booster will bolt up to the original master cyl. That way it saves stuffing around with bleeding brakes etc.
Just undo the 2 nuts and pull the MC out of the way making sure not to damage the hard lines.
Edited by SLO-030
