January 31, 201115 yr comment_499629 Hey guys just rang transport sa regarding coilovers and he said I need an engineers cert for them to be legal. Does anyone here know someone who can do this at a good price in sa? And how much should I expect to pay? Report
January 31, 201115 yr comment_499634 post your findings regarding engineered approved coilovers. :) Report
January 31, 201115 yr Author comment_499639 Is it kind of a grey area? All I have read is that suspension can't have loose, bent, cut or faulty parts :( I just rang a engineer who said it could cost about $3000. That is ridiculous Edited January 31, 201115 yr by Istartfires Report
January 31, 201115 yr comment_499659 This has been covered many times. Do you really want to pay more in engineering than your car is worth?? Only to still get defected on the side of the road by an ego filled Police Officer? Unless you are building a $100,000 exotic then don't worry about it - waste of time and money :blush: Report
January 31, 201115 yr Author comment_499684 It's for my stagea I can get it with stock suspension which is really firm for a wagon but too high :) Report
January 31, 201115 yr comment_499696 Is it kind of a grey area? ..... I just rang a engineer who said it could cost about $3000. That is ridiculous First up this is not a grey area at all. Requirements for coil overs are pretty clear in this document from DTEI. You can start your mods now and get an engineer to look over it once done. But do it properly. it's important to understand why it's expensive to engineer modifications. I'm a mech engineer and have considered getting my CPE, in particular so that I can approve coilover installs as it's fairly straightforward to do, a few hours spent to look over the car and produce a report. Keep in mind that at a fairly standard round 100 bucks an hour, you wouldn't get much change from 500. The main reason why I haven't done it: professional indemnity. If I approve a suspension modification and after a crash a coroner rules that suspension failure contributed to someones death, I am personally liable and could lose everything I own. Professional indemnity insurance is available but wont do enough of this work on the side to pay the insurance bill. Anyway, the biggest issue is getting round the heating issue, you'll need to get any welds x-rayed if you use weld on coilovers. Report
January 31, 201115 yr comment_499703 Ok well if you do put coilovers in just keep the standard struts and if you get defected swap them back in. An inspection at Regency is sub $200. That's alot of times getting defected and swapping parts before you get to $3000. Jus saying :glare: Report
January 31, 201115 yr comment_499771 keep in mind that if you stack it and the insurance company decides they wont pay because you had an illegal mod on your car, then you could be up for more than 3K. Just to clarify though, I think 3 grand is well too high. I was going to see if I could do the work for 500-750 but as mentioned for the small number of jobs I'd do in a year it would be too much in indemnity insurance. Report
