March 24, 201115 yr comment_512296 1987 Holden VL Berlina - with rego. Has rb25 engine number on the rego slip. RB25DET 5speed, using rb25det box. Engine has had the 100ks, not sure on exact K's of motor. Was told it would be around 110,000ks now. I have quite a receipts for the work done, including the head gasket work, 100ks service, tune and dyno runs plus a whole heap from replacment parts. ( headlights, taillights, interior peices etc ) The dash has stopped at 105 ***ks (series 2 dash) HKS Bar Boost gauge HSV Pedal set ACL Gasket kit, using 1.3 metal HG. New Belts, fresh fluids/filter Front mount intercooler. Full custom 3" Exhaust HKS Mushroom filter. VLT Ally rad Manual Boost Controller, been running at around 9psi since i bought the car. Dyno run shows 190kw, tuned by TurboTune 4.11 LSD - brand new gearset still being run in Koni rear shocks Kings super low springs, Re-set 35mm lower Pedders adjustable panhard bar Front strut assembly using pedders (short stroke) inserts, with King Ultra lows. Had a heap of bushes that needed replaceing redone with Superpros - have receipts for work AC Delco 180LPH in-tank pump Wahlbro external pump The car is not perfect, but still in great condition for its age. Was resprayed back in 07 in Passion Red, still looks great. Has a few little scratches here and there. The steering sometimes has a bit of a shutter when coming to full lock. There is also a small hole right in the top of the fuel tank, previous owner said he tryed to mount his amp through it or something, there is a screw in there from him, seems to keep pretty much most of it in there. Price is $8000 Looking for a clean KE30/KE55 + cash Feel free to PM me an offer or any other questons/Pictures you would like. Josh, 0433 627 738 - Best to MSG first as of work. Cheers Report
