Guest Casey-G
Should still be a c series gearbox, shafts may be a little different depending on which one but it all should bolt up, same splines ect..
Correct :y: All C-series gearboxes will bolt up to an A series block, however driveshafts vary in length between some models (as CaseyG said) so is worth grabbing a tape measure & checking. Failing that, grab the shafts & slap them in as well!
Guest Casey-G
Some shafts have a circlip and others have a bolt on flange, i think in both cases they are interchangeable though.
I think some camrys (sv21) share the same inner and outer in some cases but are a smidge longer in the center from memory. I'd have to double check this.
