June 22, 201115 yr comment_534159 How you guys going. Ive just recently acquired a what i believe is an 1998 AE100 toyota corolla (wiki search) auto as a daily driver. She was a little worse for wear when i got her, did all general maintenance. Then i noticed some puddles under the car which i at first though just was condensation coming off the car. It proceeded so i had a look under the engine and found transmission fluid slowly leaking from the lowest point of the gearbox where the gasket on the transfer case (near the cross memeber) is and bolts. And it looks like one of the bolts is missing. There's two bolts in the case but the lowest point has a hole but no bolt. I can't get a good look at the moment so i don't know if it even requires a bolt. If anyone can help me with this is would be greatly appreciated. Nick. Report
