Constant Power Lead
Is there a constant power lead somewhere in the ke 55 dash?
Because the cigarette lighting is on a switch where it has 12vc with acc. when its off it drops to 3.5 volts so i can't use this as constant power?
if i can't find anything ill just wire straight to battery with a fuse
also what did you's use as a acc ?
Edited by ChanseyKE55
