October 12, 201115 yr comment_559755 hello to all .. i have a Japanese model ke70 1983 last generation corolla with sr20det .. my front normal or uprated shock are not balancing my car proper so i am getting complete front coilover in good amount its with struttops and brake kit coming out from half cut what else do i need to to complete my front .. feed back is appreciated thanks Report
October 12, 201115 yr Author comment_559922 Get some of these lotsa lock.My link hey thx for reply i will only need the knuckles then ryte everything in my coilover are fitted above mentioned will this knuckle bolts directly or any modification soory a little noob in suspension specially older car thax Report
October 13, 201115 yr comment_560009 hey thx for reply i will only need the knuckles then ryte everything in my coilover are fitted above mentioned will this knuckle bolts directly or any modification soory a little noob in suspension specially older car thax They will bolt straight in. They are standard have just been extended. Makes you have awesome lock. Must have if your into drifting. Report
October 13, 201115 yr Author comment_560130 They will bolt straight in. They are standard have just been extended. Makes you have awesome lock. Must have if your into drifting. m more into drag and street racing drifting no Report
