October 19, 201115 yr comment_561451 hey guys I'm doing some suspension work on my ke55s but the car has already had mods done. I need to know some standard measurements if someone out there has a standard suspension in there ke30 or 35 or 55. All measurements from the front only first I need the measurement from the centre of the wheel to the highest point of the arch. second I need height of the cross member off the ground. Finally I need the height of the lower control arm to the ground where the ball joint bolts on. (so I can compare with mine as have different wheels etc) Report
