4K Issue After Swapping Heads Over
swapped heads over on the auto 4k kesev i have and the only thing i didnt label was the bloody leads, just wondering easiest way to get it running as it wont start and i don't wanna crank it over with em firing at wrong times etc
the leads were taken off the head but not the dizzy
any ideas
Turn the crank until you get top dead centre on number 1 piston. Check that you're in the right spot, both valves should be completely closed on number 1 cylinder and you should be able to clearance those rockers, i.e. put a feeler gauge in between the rocker and the valve. This means your rotor should be somewhere near number 1 post in the dizzy. Mark that lead as number one and plug it in. Firing order should be 1-3-4-2 so you should be able to work out the rest of the leads from that and by turning the crank and watching which way the rotor goes.
Alternatively, look up a picture of a k motor on google images and trace their lead path :)
cheers matey ill try the pics then try the long version
and ive tried google, confusing picking keywords for the best search lol
