February 5, 201214 yr comment_582304 Hi guys, i have a stock 1977 Ke35 coupe (3k engine) and I'm really keen to put a better engine in it. i was wondering about a rear wheel 4A-GE setup, how much modifications are involved and is there anything i have to change such as: - Tail Shaft - Diff, - Radiator - ETC... BTW no turbo or anything right now. Thanks Report
February 5, 201214 yr comment_582336 hey paul, i am currently in the same progression. there are many posts of people doing the same, Mainly the only things you have to alter is the x member and the engine mounts. the hole where the shifter comes through also has to be cut futher back. You have to look at wiring too. james Report
February 6, 201214 yr Author comment_582500 1328432789[/url]' post='582336']hey paul, i am currently in the same progression. there are many posts of people doing the same, Mainly the only things you have to alter is the x member and the engine mounts. the hole where the shifter comes through also has to be cut futher back. You have to look at wiring too. james ok, thats mateill look around Report
