June 20, 201214 yr comment_611273 Hello guys my project are almost done...know my problem is no spark on plug...was connect from coil to dizzy...( which wired for power on ecu? and more I'm noobies see the diagram engine is 4age redtop...I'm alone work this project.....urm also no signal (battery) on my Tacho..pls help me step by step :( thax rollaclub Report
June 22, 201214 yr Author comment_611726 urm Black/orange wired going to ACC/ON?and for Yellow wired same ACC/ON? Report
June 23, 201214 yr Author comment_611774 bump really need help :( the wired +b connect where? and +b1connect where? ? Report
August 2, 201214 yr comment_619153 connect to ignition swich 12volts,which is powered when you twist the key to ON position Report
