October 15, 201214 yr comment_631828 So I have the ae92 heater outlet which i need to change. My question is about the two temperature sensors? in the heater outlet.. What are they for? ie one controls the radiator fan one does the ecu.. i dunno. why are there 2? can i remove one? pinched a link to photo below.. one green plug one brown. I would be eternally grateful if some guru could tell me: brown= x green= y engine will run fine without x... thanks in advance! http://i260.photobuc...ear_oultets.jpg running standard ecu and stripped harness. Report
