April 12, 201313 yr comment_653007 Hey guys I have a mate who's selling some ajps coil overs that were in his te72 and was wondering if anyone knew if they would bolt straight into a ke70 or how much hassle it is to get them to fit? Cheers Report
April 12, 201313 yr comment_653009 Should fit, might need to use TE72 steering knuckles. I'm not sure what the bolt spacing on TE72 ones are compared to KE70. There might be an issue with the top bolt spacing too so you may need to use the AE71 top plate. Report
April 13, 201313 yr comment_653033 Yep, you'll need TE72 or AE86 steering knuckles, as the bolt spacing is different. I have TE72 struts in my late KE70. I also needed to swap the strut tops as although the bolt spacing between the TE72 and late KE70 is the same, it still bolted up incorrectly. So I have TE72 struts, AE86 PS arms and KE70 strut tops on my setup. It all bolts together easily though. Report
