October 3, 201312 yr comment_668371 Hi guys, hope you can help. My daughter has an AE92 Seca 1989 and was having problems with both front seat belts not unlocking from the retracted position making impossible to put the belts on. I bought 2 good second hand ones and now the drivers belt is acting up again. It worked OK for a couple of days and now not. What do you suggest? Are the belts specific to left and right hand side? Report
October 6, 201312 yr comment_668610 Hello, it sounds like either your very unlucky with seatbelts or they are fitted incorrectly(which is impossible to do in a seca).If the retracting mechanism is not at the correct angle/position,it will keep locking up(try unrolling a seatbelt when it's not fitted to a car,bloody hard to do,unless held in the right position). Having said that,I can't see how it could be incorrectly fitted to a seca...they only bolt in one way. I believe the seatbelts are strictly left and right but I haven't tested the theory. If you want to try your luck on another second hand set,I have a set of front and rear seatbelts with bolts from a seca for $20 set. Located at Dinmore,near brisbane qld. Other seca bits available....rear louvre...door windvisors/weathershields...rear bumper...tail lights etc. PM me if your interested. Thank you...skip. Report
November 2, 201312 yr comment_670798 might be worth a shot, silicon spray works wonders on seatbelts, fixed up mine with a few quick sprays-might be worth a it considering a can is like $10 from supershit... Report
November 13, 201312 yr comment_671719 they are definitely left & right sided. the locking ratchet goes one side only. i can usually get them re-webbed and repaired (and re-certified) thru work. as a professional mechanic, i would never fit a used belt due to risks of not working correctly. as a private home repairer you might be happy with that risk Edited November 13, 201312 yr by terryo Report
