October 25, 201313 yr comment_670148 Hi everyone, I am looking for information about installing a T283 in a U312 rear axle housing. It can be posible? The idea is use the diff gear ratio of the U312 but installing the LSD from a T283 in it. Some one could help? Thanks. Matias. Report
October 27, 201313 yr comment_670262 U series is the early corolla? E2x series? And the T is later celica and E7X series which aren't interchangeable. Report
October 28, 201313 yr comment_670315 http://members.iinet.com.au/~stepho/diff.htm T diffs are 6.7", U's are 6". You will have a crown wheel that is too small. It probably won't fit without at least being machined, or it may not fit at all. You'd have to check where the pinion sits in the diff, it's probably in the wrong spot. Report
November 10, 201313 yr Author comment_671474 Thanks for the answers. I must try to get a new rear axle. the problem is that the T283 is shorter than the U312, and the car runs ok with the 3,9 one. Do you know any alternative? Thanks. Matias. Report
