Hi all, looking at purchasing a ke55 and have a question regarding the front suspension.
Essentially I want to fit some HSD ae86 coilovers up front, but I need help with a camber top so I can actually bolt the strut to the chassis.
T3 make ke30 camber tops and I was wondering if I can use ke30 camber tops in a ke55 or is the bolt pattern different?
You don't need camber plates you can use your stock strut tops. But yes bolt spacing is identical.
Edit:S13 camber plates fit but you need to file the holes out about one mm.
Edited by B.L.Z.BUB
Awesome, ill just go with the ke30 tops, doesn't hurt to have the extra camber adjustment when needed for those track days.
