December 9, 20169 yr comment_707437 It's the off season here in the wonderful state of Oklahoma, USA. That means bitter cold and prepping for spring. I'm considering boring my block and fitting over-sized forged pistons. The only place I have found that make pistons for the 4K is Kameari and those are 88,000 yen or about $770 US. They're also 79mm which seems like a stretch in the 4K block. Is there another company that makes over-sized forged pistons for a 4K? Thanks and happy holidays, JP Report
December 10, 20169 yr comment_707445 the usual piston places like wiesco or arias will make a set for you and not at a huge cost, just fill out the form or give them a call and they can sort it out for you. should be easy from the states. 79mm wont be a problem for 90% of blocks, just have the machinist sonic tested before boring to see if they need to move the centerline a bit to get in the center of the casting. -Phil. Report
