rehau Posted April 27, 2004 Report Share Posted April 27, 2004 Hey Guys, I'm new to this forums, i own a ke30 corolla, my one is the one in the public upload, the ke30 2 dr with the L plates on it, I'm no lerner anymore. But anyway, to my question, i hate how sloppy my steering box is, and i cbf getting it replaced, what i wanted to know is, is it possible without toooo much hassle to put a ke70 rack and pinion setup in, what work is involed? thanks. Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted April 27, 2004 Report Share Posted April 27, 2004 if you cbf doing a steering box, you definately cbf doing a rack and pinion conversion! the rack bolts to the crossmember, which is different between ke30 and ke70, so you'd need todo chop chop weld weld to your existing crossmember. you might also need to find/make some tie rods that would work, because the ke70 has a larger front track than the ke30 it's not exactly a bolt in job you can adjust your steering box with the little screw on top. loosen the nut and wind the screw in to make the steering box tighter. if you make it too tight, the wheel won't snap back out of corners. to counter this, wind your castor rods as far forward as they will evenly go sometimes having the steering box rebuilt is the only way to go, i imagine whatever it's worth would be pretty worth it once you get your car back and it steers like a gokart :) Quote Link to comment Share on other sites More sharing options...
rehau Posted April 28, 2004 Author Report Share Posted April 28, 2004 Thanks for the input guys, now that you put it that way, i might re-consider putting the rack and pinion in, just migh tighten up the current steering box and see how that goes, and just a quick question, is the ke20 2dr, have the same doors, passenger and drivers door as my car, the ke30? because "not happy jan" i found a patch of bog the size of my 2 ass cheeks on the passenger side door, and woundering, seeming my type of car is hard to come by, if the ke20 doors would fit? Quote Link to comment Share on other sites More sharing options...
andrew Posted April 29, 2004 Report Share Posted April 29, 2004 i don't think they would fit as i have owned both these models and i tried interchanging gaurds and had no luck. the shape is too different. Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted April 29, 2004 Report Share Posted April 29, 2004 no, there is nothing similar between ke30 and ke20, except engine gearbox and (sometimes) diff center that being said, you can fit ke55 doors without a problem Quote Link to comment Share on other sites More sharing options...
