July 8, 200620 yr comment_127446 Hi, i have a completely stock KE20 and am looking at changing the diff ratios and putting a 5 speed gearbox in. At the moment the car is revving its guts out doing 100kms and i want to do some long distance driving in it and travel in 100km zones every day. What would be the best diff to put in and what car will i find it in? What car can i find a 5 speed gearbox in that will bolt straight into my car? Thank you Daniel Report
July 9, 200620 yr comment_127515 A 5 speed gearbox will give you over drive with a ratio of 0.865. I did a 5 speed conversion in my KE20 (Here) way back when. I like the KE70 box length, even though you have to cut a bit of tunnel away to fit the shifter in. The shifter position is just right (for me anyway). I think the KE55 boxes are slightly shorter, but by how much I don't know. The gearbox conversion should make highway driving a little more bearable. I would try and avoid going for a lower ratio diff because the 3K doesnt have the torque to cope with it. Do the gearbox first, then see how you go. Gearboxes in the FAQ: http://www.rollaclub.com/faq/index.php?title=Manual_Gearbox Report
July 10, 200620 yr Author comment_127678 Thanks irokin Will i have to change the tail shaft aswell? And what is a KE70 Gearbox worth? Cheers Daniel Report
July 10, 200620 yr comment_127770 Standard KE20 tailshaft fits fine. Its possibly a bit short/long but I never experienced any problems. I payed $150 for a rebuilt one a few weeks back. Around $100 is the usual going price. Report
