February 22, 20233 yr comment_735436 I noticed that techno toy tuning makes coil overs for the te37 but they’re also not listed for the ke30. I'm new to these cars and haven’t really been able to find anything about this. Just wanna know if te37 labeled parts work on Ke30, I have an USDM ke30 coupe to be more specific. Edited February 22, 20233 yr by Bobbyfanatic Report
February 24, 20233 yr comment_735487 Yes they differ. The TE stub axle is larger similar to all the other TE strut and ae86. TE has 85mm bolt spacing to the steering knuckle compared to 87mm for the KE3. i havent compared directly as ive never touched the TE strut. But i would assume they also run a stiffer spring due to heavier driveline and quite possibly the bigger diameter strut tube 51mm od instead of the 48mm od. Both are 4x4.5" wheel stud pattern. Report
