We used to put MX32 Cressida arms into TA22's for about 3 degrees neg.
You would need to do some measurements to be sure, but realistically you should be able to pick some up cheaply from a wrecker and just try them out. I would guess the balljoint is probably the same but you may want to research that, depending on what Corona you have
