Hi guys,
I am in the process of trying to buy some extractors, however I have notices that there are two different types.
Can anyone tell me whether the 4-2-1 or 4-1 extractors are better for a 5K, and if so why?
Cheers,
Twitch
Considering how many of them are probably anywhere near tuned for a particular motor, probably either. Both will likely be better than a stock manifold.
Yep, unless you're building a racecar, the gains will be marginal. If you are building a racecar, you'd go through the process of cam spec and then tune your manifold to suit the rev range. +3hp!
