beatle
    14
beatle's Achievements
  1. I'll give that a try in the morning, thanks mate
  2. I'll also add I'm getting alot suspension noise through that side, creaks groans etc.
  3. I've put everything in myself, the shocks are hand me down yellow inserts from a mates sprinter they were too stiff for him. I'm running xt130 lca's, I've measured the free height of the springs I'll remeasure now they are in. The wheel alignment bloke said he got everything even as possible but I might take it somewhere else for a second opinion.
  4. On it's way out?
  5. Have an xt130 front end in my ksev, I noticed the other day the 1 side sits nearly an inch lower then the other, and that on the same side the tire sits flush with the outside of the guard, where as the other side tucks in. Have had a wheel alignment, checked the springs- same height same number of coils etc. Can't figure out what's going on, Suggestions please.
  6. Been told this topic has has popped up before but can't find it. I went to bolt in some rebuilt xt130 struts into my 70 today. They still have the rotors and calipers attached, was planning on running the brakes to get me by for the moment. The problem is the steering arm bolts foul on the bottom of the brake rotor as it is located on the back egde of the rotor not the front. Can I just swap the rotors from right to left so the caliper is on the front edge an thus giving room for the arm bolts. Thanks Craig
  7. Or better yet I'll email ajps
  8. Thanks Dave I haven't been on here for a while, thort know the goods, ae86 kings?
  9. Ok so I'm running xt 130 struts, ae92 koni yellow inserts and ae71 Strut tops. Problem is finding some springs to go with it all, I've read the posts on here but all mention inserts or coilovers. I just need some spring and don't really wanna go custom or adjustable coils, just set and forget, it's only a daily with no track work. Any help??
  10. Thanks.. Its on a mates 86. I suggested wrong computer running it ill let him no.. ill take some pics 4 you's and get em up here wen i can
  11. Has anyboby tried to fit 4age 20 valve quad throtle bodies to a 16 valve head ive made a manifold and fitted a set to my 16 valve but i can't get it to run proply any suggestions?
  12. Thanks so far. Think I might go with a 4age. Its a ke70 with a stock 4k motor. seems like there is a lot more common and easier conversion after reading up a bit more. ( thanks rollaclub) Keep the thoughts coming tho. I also have the means 2do the conversion myself just after the easier one
  13. Hi all. I'm a noob to this but have been a long time fan of rwd rollas. looking at buying my 1st one this week, and would like some help with what engine to go for. Tried and tested 4age or a beams engine as I understand these are already rwd orientated and would be and easier conversion. any help wood be appreciated.
