Everything posted by mx83dylzy
1jz No Start Ems 8860
i know that jzx81 is ment to a lot of people use jic one for them in mx83.. am thinking bilstien made up 2 suit is looking the way 2 go atm...1500 seems lot cheaper then some costs heaps importing cos postage n crap and everything can get ere i hear bad things about
will investigate cheers m8..so limited in range for them it seems.. they don't do it for jzx81/mx83 lame lol
yea am looking round at options not doin heavy track just like occasional. best option thus far seems to be making my struts into coilovers running bilstein adj inserts valved to match 12/8 spring rates cheers Dylan
track worthy? were you get them cheers
ahahha ecu battles i had 2x ems's now one was awesome second was jus confused now I'm hoping will be awesome :) now gotta sort some suspension cressy in squatting machine atm.. am keen 2 get a decent drive 2 as on properly lic lol.. not easy find decent coilovers is same people like some things others swear there the worst product in the world lol confused!!!!!!!!!!!!!! coilover battle comense :wink:
hahaha ems is ok atm.. need get licenced now!!! is so hard not to drive everywere :blush:
appaently they done something and now fixd all thy said was set up needed work... got back now 345rwhp can't wait to get it legit :dance:
am sending off first to see if can be repaired at a lower cost.. otherwise i am unsure is running on 4 atm but think is due to beeing wired wrong by previous owner.. have ems ignitors now so prob ems still and superspark coils so spark should be there if i ever get a decent ecu in there.. spent sooooooooo much on dyno and tow 4 crap all atm!!! so much 4 these ecus never going wrong hey... that was the only reason i didnt have it tested because when i rang dealers they sid will never go wrong :blush:
ignitors installed ecu stuffed is now the official verdict yay!!! so much 4 my cheap project!! :bash: :no2:
apparently is commen with jz and rb30 ignitors and ems ecus, so ems ignitors on the way lol..will let u know on the 7th
made 245hp @ 10psi on dyno boost blowing spark out waiting on stock ems ignitor and tune on the 7th.. is running tho sounds mean :y: gonna have quieten 4 pits :(
i recon selling my chaser now so can get all goin need legal exhaust+tune+master cyl now list goes on and on not even looked at susspension and body yet needs set coilovers swaybars and decent bushes badly!! :cool:
aparently some wiring was wrong am interested 2 know what wiring i missed when diagnosing..but am happy is running awaiting tune will post how goes need to fix few things b4 can be tuned:) $$$ have blown out a lot but maintaining optimism :dance:
cheers m8
yea did carby clean wants 2 go dam injectors!!!!! is going 2 ovaboost 2morrow theyll prob fix in minutes lol... man cars a pig atm now brakes wont bleed up needs master cyl rebuild and id say booster as leaking back into it! never ending!!! >|
yea after manually earthing injectors it actually coughed 4 a second instead of jus cranking obviously cos fuel was in cylinder jus don't get y injectors wont work from pulse provided...
with the spark? yea m8 has spark..
has coil over plug 6x put power direct to inj loom made no diff.. earthed inj individually click was very evident.. added 2 wires to earth wire at ecu jus so earth was 110%... nothing.. is it possible the ecu is not earthing internally enough so doesn't let injector activate... anyone in perth got a 8860 installed willing to plug mine in to see if fires up on an already proved system?? carton 4 anyone who can!!
was 11.6 last time i done it on crankin batt was down a bit due 2 leaving charger off accedently :blush:
yea just chucked boost gauge on the line has vacuum.. all 2gether now just cranks and does nothing
been saying that ages now lol stumped.. earths at ecu ok power there.. pulse is there is random thing 2 me... tuner saying do full rewire from start again i don't think i have the know how 2 do it and dunno wats even left 2 do.... $$$$$$$$$$$$$$$$$$$$$$$
should be firing ay lol
both 13.6 ecu is set 10-16 ohms
yea yellow but is pretty fn cold hahaha sard ones are ment to be 16ohm according 2 box for them that was in the car
wen 20k selected on meter they both come up at 0.01
