went over the setup today
all sorted
there is a sleeve about 10mm long that sits between the
top spring plate and the camber plate itself
thats what i had to make
without that the spring top plate pushes right up to camber plate
which also limits the movement of the pillow ball
thats why the big bolt/nut was being pushed up when the car was dropped
ive been sort of thinking about it
maybe the camber plates are different thicknesses will check them
i reckon its most deffinatly the bolt moving up and down (which i maight have not screwed all the way down)
making the noise
which sort of makes sence since it does slide up and down when car is lifted
also the big bolt do i tighten it till it wont turn anymore
or just tighten it enough to hold
so i got my slef some s13 coilovers with ae86 camber tops
i put them together
but
when i drop the car on its wheels the big bolt on the camber plate pushes up about 10mm
and when i jack the car up it goes back back down
it doenst seem normal
also knocks when driving
is this a failure of shocks or just simply needs proper adjusting
cheers
