March 16, 201115 yr comment_510324 so i got my slef some s13 coilovers with ae86 camber tops i put them together but when i drop the car on its wheels the big bolt on the camber plate pushes up about 10mm and when i jack the car up it goes back back down it doenst seem normal also knocks when driving is this a failure of shocks or just simply needs proper adjusting cheers Report
March 16, 201115 yr comment_510394 I'd be going over everything and making sure all the bolts and nuts are tight. And while the front end is up i'd be also grabbing hold of the strut and give the thing a few good quick push/pulls. That big bolt that you said about, should be hard up against the camber plate and there shouldn't be any movement up nor down. Its the shock absorber which is possible the knocking sound your hearing. Report
March 16, 201115 yr comment_510405 The only way to do up a shocky nut properly is with a rattle gun and heaps of small pulses of the trigger. It'll pull home. Sometimes with the weight on the car you can get them up tight with a breaker bar and some vice grips up high on the shock so not to damage the part of the shaft that runs through the shocky seal (not recommended - use a rattle gun). Report
March 16, 201115 yr Author comment_510409 ive been sort of thinking about it maybe the camber plates are different thicknesses will check them i reckon its most deffinatly the bolt moving up and down (which i maight have not screwed all the way down) making the noise which sort of makes sence since it does slide up and down when car is lifted also the big bolt do i tighten it till it wont turn anymore or just tighten it enough to hold Report
March 16, 201115 yr comment_510413 Can you get pics of the setup to see if you have left anything out? Report
March 17, 201115 yr Author comment_510506 went over the setup today all sorted there is a sleeve about 10mm long that sits between the top spring plate and the camber plate itself thats what i had to make without that the spring top plate pushes right up to camber plate which also limits the movement of the pillow ball thats why the big bolt/nut was being pushed up when the car was dropped Report
March 17, 201115 yr comment_510512 good work! thats exactly what i was thinking as i was reading down the thread. i had the exact same issue when i used s13 camber tops with my 86 coilovers (sw20 shocks with some coilover kit, otomoto i think). had to get the local machinist to machine up a small sleeve to take up the slack between the spring top and the camber plate, and allow the camber plate to properly pivot. Report
March 17, 201115 yr Author comment_510625 yeah i spent half the day goin to fab shops and engineers to see if they had anything like it not realising i had what i needed at home Report
