GiGas
Everything posted by GiGas
  1. Just got this answer in an other forum, if and my work can contiune. In Case any one can use it, here it goes. All color match my loom. From a loom I stripped, I have the wires numbered left to right looking at them from where the wires go into the connector(engine side) Top row 1 Black/White Air Con 2 Red/White Batt +12V 3 Blue Fuel pump relay 4 Brown Earth Retaining tab Retaining tab 5 -------- 6 -------- 7 -------- 8 -------- 9 Yellow/Black Air Con Bottom row 10 Black/Red S/C relay 11 Black Starter solenoid 12 Light Green CCO in Diagnostics 13 White/Red Air Con 14 Brown Air Con 15 Blue ?? VSV 16 Blue/Black Fuel pump relay 17 Blue/Yellow Fuel pump relay 18 Red/Yellow W in Diagnostics 19 Black/Yellow S/C relay 20 Blue/Red ?? VSV
  2. Hi folks. My native is Danish - excuse my "dinglish". I am in the middel of implanting an Japan AE101 4A-GZE engine in an Euro AE82. Manny people over here choos to modify the AE82 ECU and AE82 engine wiring, but I see manny piston meltdown when that method are used. I have choosen to install the ECU and engine wiring from the JAP donor AE101 4A-GZE, this include replacement of the J/B No2 and a lot of re-wiring to J/B No1 and J/B No4. So fare I mannaged to finde wiring manuals holding diagrams over the AE82, and have all ECU pin outs diagram over the Jap AE101. And, as of to day, most of the wiring job are all readdy don. I do still have a few unsolved wiries from a grey wireplug that is called IF2 in Toyota diagrams, but no information nor pin outs are to finde in the manuals i mannaged to find. IF2 connector is a wire-plug to wire-plug connector, form the Jap AE101 4A-GZE wiring, and are located close to the ECU, some wires are going to the ECU 22 pin plug and I belive some are to be used in the multi gauge meter. But I do need the electrical wiring manual Jap AE101 to finish this job. Hoping some one can link me to a wiring diagram holding the IF2 connector used in AE101 (probably all models). Thaks GiGas
