shoedoob
  • Real Name
    Jon
shoedoob's Achievements
  1. I hope this is on topic as I feel it is. I have a 83 AE71 4A-C with an auto transmission that I'm currently looking to swap with a manual. I found someone offering an AE86 SR5 manual setup for sale. Previous research has lead me to believe: The bellhousing will match since it is a 4A motor The clutch and brake pedal can be installed with minor modification. The master, slave, soft and hard lines should fit with possible minor modification. My unanswered questions are: Will the AE86 transmission crossmember fit in my AE71 or can I use the original AE71 auto cross member? If not, can either one be modified to fit? (The pic above leads me to believe so) Will the AE86 driveshaft fit with my original AE71 SR5 auto diff? Length, bolt pattern, etc? Is there anything else that I need to find that is not available between the two assemblies? AE71 manual transmission mounts for example? Thanks!
