rosco-ta22
    3
Everything posted by rosco-ta22
  1. not 100% sure, but a ae95 awd corolla diff is 1325 mm. drum to drum, i think its coded T462 ..think they are 292.1 ratio...there is one wrecking on ebay.. you could ask?..hope this helps
  2. Axles: Displaying 2 axles Code Ring Gear Ratio Centre Width (mm) Weight (kg) Linked Chassis T312 6.7" 3.90:1 2-pinion open 1410 N/A T312 6.7" 3.90:1 2-pinion open 0 N/A
  3. yes if that was the code on the cars,t312 the code means = t series x 3.91 ratio x 2 pinion, there are 2 lenghts 1375 and yes 1410 . 1410 should have larger bearings from memory 71mm and 25mm axles, axle lenght is 690 from the hub face, both axles should be the same lenght, p.s.if you have a spare axle let me no need one
