not 100% sure, but a ae95 awd corolla diff is 1325 mm. drum to drum, i think its coded T462 ..think they are 292.1 ratio...there is one wrecking on ebay.. you could ask?..hope this helps
yes if that was the code on the cars,t312 the code means = t series x 3.91 ratio x 2 pinion, there are 2 lenghts 1375 and yes 1410 . 1410 should have larger bearings from memory 71mm and 25mm axles, axle lenght is 690 from the hub face, both axles should be the same lenght, p.s.if you have a spare axle let me no need one
