Do I Have A T Series Diff?
hey guys,
so i bought a t series diff out of a rt132, i plan on cutting all the mounts of and setting it up for my panel van. i pulled two out and got all the got bits and spare axles. both have 10 bolts same axles but one of them has a lone stud in the diff housing and one doesn't what does this mean? i should of researched more but both cars had t312 diff codes what are the differences between the two?
thanks guys
Edited by iwontarolla
Measure crown wheel dia (6.7inch) ,and axle dia should be 24mm.The axle face to axle face should be 1410mm.=t series
Not sure about the extra stud ??
rob
Edited by dbr11k
Lone was a auto correct. There is no long stud in the housing, between the two the centre housings where both diffenrent.
I'm a little confused how you measure the crown diameter?
Every thing leads to it being a t seires, but I just have never seen one with no long stud.
yes if that was the code on the cars,t312 the code means = t series x 3.91 ratio x 2 pinion, there are 2 lenghts 1375 and yes 1410 . 1410 should have larger bearings from memory 71mm and 25mm axles, axle lenght is 690 from the hub face, both axles should be the same lenght, p.s.if you have a spare axle let me no need one
Axles: Displaying 2 axles Code Ring Gear Ratio Centre Width (mm) Weight (kg) Linked Chassis T312 6.7" 3.90:1 2-pinion open 1410 N/A T312 6.7" 3.90:1 2-pinion open 0 N/A
