Ke70 Engine Conversion.
what about the wiring harness from the sr, would i just plug it up and get power to the srarter and an electronic fuel pump and it would go?
4K Running Like A Dog
nahh i havnt, done a compression test, could the rings be fryed? or would it be the head?
4Kc
What work does this evolve you doing?
Hey I'm new to these corollas, and I have a 4kc in my ke70 and it's running like a dog the second last cyl is not firing, ive changed the plug and the lead and it's still not firing but it's sparking, I can pull the lead off and it will run the same at idle and revs! Is it a sticky valve or what's the problem
It's a ke70! So could I use an ae71 pedal box?
so i couldnt use the factory pedal box? is just want to get it in and running at the moment, its not going to be a track car..
i have just brought a ke 70 and plann on doing an sr20de conversion, id like some guidence and id like to know 100% everything i need at this stage i only have the engine,box and loom! if you could help me out would be a grate help thanks :)
ke7o
